my house mate told me yseterday that he brakes are making noise....
just had a quick look, i think i can see the problem...
can u say metal on metal?
those are the deepest grooves i have seen on a disc, they are about 3 - 4 mm deep
yeah looks good Matty but don't know how comfy the Patrol boys would be having a 200 around..........lol, it won't matter whether I can keep up with them or run rings around them, the fact that it's a 200 will get me flamage.
EDIT: Not to mention that I'm still running the factory Dunlop Grandtreks (crapiest tyre ever designed for a 4WD). Need to put some M/T ATZ's on there but I'd be looking at almost 1/2 grand a corner :D
i dont think they'd mind. someone always brings a mate along with another make of 4wd, there tends to be floaters with pajeros, cruisers and the likes. even on the Patrol Club of SA outings they've had Jackaroos and Subaru 1800 wagons :(
Im keen to see how the new Kelly Safari Trex go
i want some custom slots like that in my rotors too. it has a great feature of screaming like a banshee all the time... i need that too
just get some RDA slotteds from Rianto (rs73)... he'll hook ya up for a good price :D
-D
just get some RDA slotteds from Rianto (rs73)... he'll hook ya up for a good price :(
-D
unsubstanicted clap trap i dont appreciate that post there is nothing wrong with RDA rotors its the pads and how you bed them in
dont take this the wrong way
haha cheers craig :D
I never said anything about RDA rotors except to buy them. I've ordered some myself... WTF kinda high horse are u on today? Don't appreciate what post?
-D
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
