It's less risky when you use a broker who knows what they are doing and have the right contacts in Japan. Keep in mind though that things can still happen that are out of their control as well.
I'd buy another car through Kristian (Iron Chef Imports) without hesitation, although I'm trying to cut down on the whole buying of cars thing :3some: (18 in 6 years is a bit excessive).
its deff something you wanna spend some time reasearching unlike my stupid bro that tried importing a car to have it sit on the docks. we tried getting it in as as a race car only and they still shut it down based on -does not meet aus safty standards
hey Penny, a guy i work with (he is on here but dont think he posts much) is looking to get a turbo conversion done to his 34 GT. he has a workshop lined up, and all the info. i can get him to get in touch wit u if ur keen?
Yeah that would be great thanks!
Will be good to compare my options, cheers :3some:
KKR are ass. Cheap, laggy, etc.
You be the judge:
http://www.skylinesaustralia.com/forums/Kk...od-t183792.html
http://www.skylinesaustralia.com/forums/Kk...33-t260106.html
http://www.skylinesaustralia.com/forums/Tu...wn-t253002.html
http://www.skylinesaustralia.com/forums/Ch...it-t251203.html
http://www.skylinesaustralia.com/forums/Fm...os-t251603.html
http://www.skylinesaustralia.com/forums/Kk...80-t249134.html
http://www.skylinesaustralia.com/forums/Kk...ns-t245965.html
http://www.skylinesaustralia.com/forums/Kk...rs-t229806.html
http://www.skylinesaustralia.com/forums/Kk...ea-t216361.html
http://www.skylinesaustralia.com/forums/Eb...es-t236327.html
http://www.skylinesaustralia.com/forums/Kk...os-t237320.html
"I just bought a KKR turbo, installed it and now I hear a whining sound when it comes on boost..."
"I have a KKR turbo and when I hit boost, there's a cloud of white smoke behind me?"
"I just bought a KKR turbo. Then my wife left me. Then I heard a metal clanging sound when it hit boost?"
And the topics just roll on...
i donno, there's alot of good and bad in all those posts.
to be quite honest, when i drive the silvia, she gets one HELL of a beating. and that turbo has gone through hell but its kicking pretty strong still.
i guess i cant give a full comment about the kkr as mine's a cross bred with garret and the wategate has been sorted out already but im pretty happy with my 1.8ltr turbo that can stomp a 6ltr v8 :3some:
too much in this thread to pick apart everything specially on 64k and now I've had too choose the PDA skin to try and optimise load times
someone made mention of sensible's im guessing you mean the one on OG rd, that's where i bought my car and had no drama's had snapped turbo manifold studs got them replaced had worn rear brakes got them replaced bought the car without driving it only hearing the engine NOT because they wouldn't let me drive it but i didnt want to fall in love with the car and have finance fall through
Ben - this should hit that itchy spot
SpaghettiSpoon467Three.jpg:3some:
hrrmmm cars been in the workshop for a month or so now and i'm feeling withdrawl symptoms :woot:
I hear ya. the gtr has spent almost a week of the last month at the mechanics getting loads of stuff done... *sigh*
The angst of owning an import haha
-D
what's happening to yours?
so far i've had major service (timing belt, tensioner kit) n1 water pump, isc radiator, new hosing and nissan coolant installed, i got brakes and pads on order and after that i'll be putting in N1 turbos and a new gearbox... its currently there getting a cracked heater core hose repaired... fun stuff
-D
nice
Im off soon to pick up my ordered sparkies, and to grab a 30%-angled thermalflex ply silicone joiner hose + a cple tbolt clamps
finishing off the piping properly, then might get a mandrel bent 2-piece copy made of the intercooler piping system Ive tee'd up
also put mesh around the front of the bar, looks amazing TBH :woot:
(cut bottom of day bar, big fmic tucked behind black mesh)
then dropping off the missus for her last wrist surgey (carpel tunnel, right wrist a success after 7 weeks, so here goes
hope Pokie has a good birth today
our friend had little Jye last week, nice boy to join 2 sisters
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
