Dammjust got back from my regency appointment and failed :D .
Got done for tiwsted brake line but it passed the brake test.
6 x 9 speakers in the back so they cut the metal parcel shelf and parkers and low beam on 1 side.
Does any1 know hwo or where i could get to fix/ put in a new metal parcel shelf???
please help
Can be classed as structural support, so hacking away at that, in their eyes, is a big no no. In some cases, this means the rear parcel shelf needs to be engineered before you can pass Regency. That's happening alot these days.
friend called me today, his sisters boyfriends pimped as dr30 was stollen last night/early morning :P
was such a old schooler look too :)
ill see if i can get more details, was stollen around the woodcroft area though
Why you selling stockies?
Did you get that roll and flare done? How the rims going?
Coz i dont need them, they arent legal for regency so theres no real point in them laying around, a mate of mine wants to buy them too.
Havent got roll and flare yet. Rims going good!!!
You got your XD9 set yet?
What XD9's?... :P
Yeah I got them here. Using them as a kiddy pool for the dog. :)
... its currently there getting a cracked heater core hose repaired... fun stuff
Well got the beast back and while it took the guys a while to get to the rooted hoses, it was worth it. Not only was one ruptured and spewing my precious nissan coolant all over the front diff, but there were two others very close to giving way.... probably I could give advice to anyone with a 20yr old GTR that hasn't yet replaced the hose, now is the time ;P
And now I can drive without my car stankin' like anti freeze and peeing chloroform
woot
-D
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
