So in otherwords im pretty much farked and its gunna cost me a shitload. So no matter what im gunna have to get it cut out welded in new then complied then checked thru regency because what 10mm of metal was cut out!!!!!!!!!!!!!!!
Yeah all lights were working but not having driven the car let alone at night for 2 months as its been defect genarally makes it a little hard to tell, since its illegal to drive the car on the road day or nite.
Im sorry but 10mm is bulls##t. To defect on that which is gunna cost some1 whos not hooning around breaking the law, asalting ppl just enjoying motor vehicles is crap
did they go right for them? its stupid you can drill a hole for FMIC pipe but not 6x9? the fmic hole would affect the crumple zone more then 6x9.
i was within a day of cutting my rear deck to port the sub thru, damn it!!!! do i rethink the port or hide it really well under carpet on deck and block access from the boot to speaker deck ? REGENCY SUX end of rant.
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
    • We want to see pictures of the carnage!
    • The picture of the underside of that PCB shows either old flux that wasn't cleaned properly or some other contaminant (I.E Water). I would flush it with ISO and try again.
    • @silviaz Are you skim coating the entire panel (covering the entire panel with filler) before your hitting it with the long block? Or are you selectively applying filler to the repair, trying to fill the low points?  Please don't do that.  Almost certainly. Are you checking the panel for flatness as you go? Or is it more a case of, sand til all the guide coat is gone then check?
