just thought id give an update bout my over sized internetz yo' bill....
yup, apparrently i downloaded nearly 20 gig,
the way i was keeping track of it, is ''outdated'' as i have the ''old modem'' (words of indian/asian from optus)
so...therefore, on the 26/3/09 when i checked my usage (last day of billing cycle) it said 6 gb downloaded, it was in fact nearly 20.
they failed to tell me about this, my download speed didnt even slow down!
do i have a leg to stand on here? may to get the bill reduced? pete? anyone? question mark??
Bend over and use lots of vaseline! :D
Tracy use to work for the Optus complaints dept (for people like you) and there's not much you can do sorry. :D
Absolutely. If the AUP was not working then its grounds for a reduction - providing that there is no clause in the terms and conditions which waive liability if the meter isnt working properly...
I'd call the telecoms ombudsman - they handle broadband complaints. tell them that you checked on the last day of the billing cycle and that it reported 6gb and not 20. If optus has changed the way the meter works/have broken the traffic accounting system without notifying you or providing a viable alternative then they have no option but to refund the difference. You'll still have to pay the excess 1GB naturally but with enough kicking and complaining I think you have a good leg to stand on here, especially if they provided the modem (im assuming you're checking the download usage by your modems inbuilt meter rather than a website on optus?)
regarding slowdowns - either you get a capped limit and anything over is free but on dialup speeds, or you get full download speed and any excess is charged on a per megabyte rate - its one or the other and you'd be best off clarifying exactly what here, because its one or the other.
-D
its there fuukin fault really for giving me a device that misleads usage!
haha, they even said if i wasnt happy with the service, i could pay another grand and cut the contract early by 7 months....
fuuk you optus.
yeah ben, i check usage on the stats tab (from the modem)
they said since the new modem has been released, the old one (mine) doesnt count correctly.
Well then they're up shit creek for not a) supplying you with a modem and b) notifying you of the change.
You'll win. Easy.
-D
the ombudsman agrees, i have to call optus, and request a stop credit management.
i have to pay 49.98 (usual bill) and optus has 10 days to respond to the TIO in regards to the 1003.98
Good work! Its amazing how many times these arsehole internet providers try and shaft you. Always the big guys like Optus and Telstra (telecoms companies providing internet as a service)... I can guarantee you that Adam and Internode wouldn't pull that nonsense (Adam and Internode being primarily internet providers and not massive corporations trying to get more for their shareholders)...
I think Optus will argue that since your modem showed 6 gig out of the 5 gig limit that they're entitled to an additional $150 - this might be the only problem you'll have, but even still $200 is much better than $1100 - if you can get away with $50 only then that'd be ideal..
In the meantime, I'd advise everyone out there (in SA at least) to switch to either Adam or Internode - you'll get one hell of a better deal.
-D
cheers for the advive there Ben, much appreciated!
my mate is with internode, after his download limit, his speed is cut down, and DOESNT get charged for over use.
guess where ill be taking my custom soon.
i dont mind paying 200 bucks, fair nuff, but over $1000 for 1 month internet? c'mon, get real.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
