news.com.au has to f**king go. this is my response to the topic http://www.news.com.au/adelaidenow/story/0...5006301,00.html
The article itself is benign however the poll has two loaded questions. loaded meaning any media turd can twist the results to his or her own devices.
This is what I wrote to them. I doubt they will have the balls to publish it, let alone act on it.
Lets see if they grow a pair of balls, or a conscience for that matter.
f**king scumbags.
-D
nicely said ben.........nicely said.
all i can say about the media in that article is go and get f'd ,
im fking sick of these immature little pricks who think cars are toys and try drift n shit on public roads
thank you for ruining it for the rest of us !
its a 32. :)
and it was posted on the last page. and in the track thread.
and i have to do this,
ladies and gentlemen,
the game.
that is all.
Edited by scandyflick
its a 32. :)
the game.
that is all.
oh yeah closer look at the back of it, its a 32...lol time for bed..lol
.... my mate is with internode, after his download limit, his speed is cut down, and DOESNT get charged for over use.
guess where ill be taking my custom soon.
When you sign up to an internet plan you agree to the terms and conditions. Simple as that - y0ou chose a plan/provider that charges for excess downloads.
i dont mind paying 200 bucks, fair nuff, but over $1000 for 1 month internet? c'mon, get real.
You physically CAN NOT download 20Gb of data and thought you were only using 6Gb. Unless you had P2P running 24/7 and shared out the 20Gb, of course - but in that case you shouldn't have been so stupid.
Either way, you did the data, regardless of everything else. If I was Optus, I am sorry to say, I would f$%k you hard.
No-one wants to accept the consequences for their own actions anymore .... a sad world when everything is someone else's fault.
Can you confirm that your usage was download data, and not upload? If it was indeed upload I have some sympathy for you, but if you actually downloaded 20Gb of data, then you MUST have know you were smashing your download quota of 5Gb.
lil help on assignment.
well its not really important but i wanted to add it. anyone know how many cars you can sell before you become a business? or where to find that info
Pretty sure Andrew knows :)
NOVA 91.9 this morning mentioned that they are shocked at another hoon driver crashing (red 32). However, they invited people from "the culture" (hoon) to ring up and say what is really going on. Didn't hear any callers however, anyone else hear?
I heard a little of what was said on Nova this morning. Didn't think there was too much constructive content and they has some drop kick loser try score points by telling listeners that he's clocked 250Km/h down South Rd in his VL Turbo.....
According to the article, serial offenders can actually have their cars seized and crushed.
Does anyone else think that is friggin ridiculous!!!!!!!
What if the car is an R34 GTR? that's some serious $$$ going in the crusher,
that's not even the point though, they can't effectively steal your car!!!!
That's absolutely disgusting, I had no idea we were living in a dictatorship.
What if the car is an R34 GTR? that's some serious $$ going in the crusher,
I heard the cars of value would be sold off to compensate victims of crime, and low value cars (shitboxes) would be crushed.
The way I see it, some decent cars are being written off by hoons anyway. The end result is almost the same, but the driver/passenger gets hurt/killed in a crash.
Edited by RubyRS4
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
