I have stated what I think the effects of crushing will be in the other thread.
Honestly, not like I ever hoon, but if my car got crushed you would probably want to lock me up.
YOU CRUSHED WHAT ??!?!
Sorry had to be done :)
Edited by KISIN
Ok then Shazmo guess thats another story for another day???
Andrew, the net is the only thing keeping me awake at work atm, daughter didn't want to settle last night have had bugger all sleep!
Sitting here doing nothing is the only thing stopping me from going on the playstation and doing nothing or going out for a drive to buy food.
In short I am so fucking bored of having nothing to do, and the more time I spend on here the more I hate it.
Edited by AndrewJZX100
How stupid are some people? :kiss:
I went to Autobarn at lunchtime. Got back into Stagea, start the car and start backing out of park. Guy and girl see me moving and quickly walk across my path of travel. They slow to a walking pace and glare at me thru my back window as I keep moving. Girl thumps the back of the tailgate. I hit the gas hard for a bit and she squeals and jumps out of the way. I stop and wait for them to start mouthing off, they get to the entrance and the GF flips the bird. Stupid. :O
Who the f**k intentially walks behind a reversing vehicle? I should just run over them. :)
the heat boils the mush called brains.. idiots, should have shot out a flame,..lol
yea shane i'll tell u next time ;)
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
