IOm with craig 33 on this one roo.
Hes probably just trying to find ways to get more off the price. Ended up being a tryekicker/joyrider. DICKHEAD
With the engine idling you should be able to hear it leaking around the area with the old garden hose to your ear trick id say
Yeah, it sounds like a minor screamer. Which I had always assumed was just the wastegate opening and the fact it has a bellmouth dump pipe. Happened with the last turbo too ... leak both times? So its either normal, or I got a small exhaust leak. No performance loss, no loss in boost, just noise. I'm aware of the hose-to-ear trick and I'm giving it a go tomorrow. Only does it high rpm/max boost.
Still wouldn't mind just putting mind to rest and ticking that one off the list. :ermm:
I'm certain he was working on knocking me down in price. Asked me if I could take Stagea to boostworx for a check, then if all okay he'll buy. Nope. Done that before in the past. Potential buyer got me to take it to Hitech and came up with false problems and tried haggling for a free car pretty much :D Then left me with the bill for the inspection. Never again. As is, or not. :P
I'm certain he was working on knocking me down in price. Asked me if I could take Stagea to boostworx for a check, then if all okay he'll buy. Nope. Done that before in the past. Potential buyer got me to take it to Hitech and came up with false problems and tried haggling for a free car pretty much :ermm: Then left me with the bill for the inspection. Never again. As is, or not. :D
That could be the case, but I know when I bought my GTR off David, he already had the report from Boostworx... so I paid him the price he was asking :P
-D
EDIT - Anyone out there not doing anything this weekend and can change my front rotors for me? :\ I have NFI
Edited by Dohmar
Ben, grab my number from my profile and give me a buzz tomorrow morning.....not sure if I'm free yet but I'll have a better idea then......it's not a hard or long job
Thanks guys :ermm: I'll call ya tomorrow Pete, and Luke thx if Pete is busy I'll def hit ya up
Cheeeeeeeers
-D
yeah nice manners there :)
first quote spot on your forget a lot of people do know you though, Adelaide is small and the things you do people remember, and Dan is hardly an old coote
your initial response is from the ol' truth hurts saying
thanks Steve :cheers:
QUOTE (Madaz @ 3 Apr 2009, 06:38 AM) *
i think maybe someone might have been caught out Dan :cheers:
Edited by nos man
do people out south all drive 800cc 3 cylinders diahatsus and not do anything illegal or "hoon"-like while driving?
dont make me pull the statistics out that the advertiser printed in there "hoon" article, went something like northen area 400ish, southern area 100ish lol
i think western suburbs actually did well, they had the lowest number of hoons caught (hoon being anything from a burnout to drink driving bare in mind)
maybe they just hoon harder and dont stop for the cops
down the dirty south cops might be scared to pull those mofo's ova :cheers:
another thought could be maybe the cops are more quick to slap hoon charges on people around the north than the south. maybe for failing to indicate when turning or attempting to keep you carby injected fuel management system idleing at the lights(being your right foot)
Edited by Inline 6
dont forget graffiti...
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
