/random thought
im a loser
all i do is sit on my computer expecting a job to come to me.
wish i knew WTF i wanted to do , sighhh
Just a few things you can do:
-Go to an job agency and tell them your circumstances
-Call up Centrelink to see what kind of allowances and programs you can sign up to there
-Use Seek and CareerOne to keep a look-out for jobs, even in things like Customer Serice and Sales.
-Learn how to draft up a cover letter and resume, or get the agency to help you with that
-Do some work experience with a small business if you want to work in an office environment, or sign up for a trade/appenticeship
-Ask your family, friends and family friends to see if they have any odd jobs or work experience they can offer you.
Good luck!
Here's some wierd shit that happened tonight.
I was cruising to town with a mate to grab a bite to eat. We go through the stupid round-about thing in North Adelaide.... this guy on a motorcycle with P plates, and no helmet tries to squeeze in between my mate's 350z and another car... he gets through, then he cuts me off (if i didn't brake he'd be on my windscreen)... my missus and I thought fark this guys either pissed or trying to get away from someone... then about 15 seconds later i see him wedged underneath a late model falcon.
We all pull up, to see if everyone's alright... the dude on the bike had hit the falcon in the left hand door side, and his shoe is still wedged under the rear wheel. The bike guy is bleeding down the neck... goes to pick up his bike still dazed, and then as the driver he hit helps him onto his feet he jumps back on his bike and hastily rides away with us all trying to stop him.
Like I said some wierd shit LOL.
so would these wheel fitment stick out the guards on r34 gtt 4 door?
18x8.5 +33off fronts
18x9.5 +38off rear
just buy some r34 gtr rims and paint them
or head down to Bobjane T-Marts he's got some FULLY SICK chrome specials happening at the moment in his latest catalogue
ahahahah
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
