Dunno if anyone gives a shit but I thought I'd share and give a heads up that the Battlestar Galactica prequel Caprica has leaked online 10 days before release... watching it now, hoping for the same awesomeness as BSG :P
hi all, hope you had a good easter. as some of you know i do abit of mechanical work on the side. im looking at doing this properly as a part time buisness aswell as continuing my regular job and just looking for advice from those who have done similar, good accountant to use,what to look out for, possible dramas, peoples opinions and recommendations.
rob.
Wow, I never knew that Dom was like that, I know they are all stories and he said she said bullshit but seems like he's screwed a fair few people...
Funny thread none the less :blush:
Moral of the story, always pay your bills
Nope, not a clutch, although I'm curious to hear that story!
when his car was being loaded up to go to blood sweat and gears, it still had the factory fitted organic clutch, that burnt out loading it and unloading it from the trailer, so he blamed the transport company, the transport company obviously wasnt responsible (nigh on 500kw car, organic clutch, smallest slip will kill it), but did the right thing and got xtreme to hook him up, one rather expensive clutch later, he was back in the running, but was expected to pay for the clutch, last i heard it was still in small claims. and thats straight from the guy that transported his car.
How we looking for the car part fitting weekend Dave?
lookin good, gonna tackle a fair bit of it tomorrow (coils), then well just need a couple hours on a friday or saturday next week to fit the brakes (fingers crossed).
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
