thinking about changing to one of these
wait till you throw a balance shaft on the 4g63, mine did off idle , a very common problem, destroyed the block in seconds. and the all wheel drive fuel economy sucks.
mitsu dependability :cool:
turbo failure a few months later, and a few clutches, gearboxes, and transfer cases later.. good thing it was only a daily not a racer, or it would have never made it to the race track...daily driver, hell it was broken down more then it worked..lol
and that was on a basically stock tune evo/vr4 drive train, not a highly tuned monster.
plus R34 prices have fallen into the toilet for resale ?
go for the Lada..lol they come with duct tape and bailing wire to make them last forever..lol
I drove Munro's Evo 8 when it was brand spanking new and it really didn't inspire me .... and looked like a chick's car .... yawn
At the end of the day it is STILL a lancer
so i went to lonsdale to get my r32 inspected (vic -> sa) and of all the things i could possibly get picked up for...window tinting...
'too dark on the rear quarters and the whole rear window'.....silly stuff, guess im back to peeling...
mitsu dependability :(
I knew someone would piss on my parade :(
parade pissing is awesome.
a 19mm nut on my front left strut pissed on mine, last person to work on the suspension partially rounded it. cant fit a 19mm anything onto it. pu.
Did they let you drive it away from there? When I changed over rego at Regency on my old MX6 in 2002 they gave me a razor blade and told me to get the tint off on the spot, else get a tow.
Sounds like a light angle grind on each side then a shifter spanner or locking pliers Dave. Works a treat!
+1 have done this a few times,
also a thin file on a rounded phillips head makes for a good ghetto once off flat head fitting
anyone know when/how carsales.com updates? or anyother sites i should check out
im pretty sure tradingpost.com is every thursday but i dont know about the other sites.
i like to keep my eyes peeled for any 240z dato's for sale amunst a few other oldschools. 14k is the best ive seen for a clean 240 so far.
cops wont hate on it and i might even be able to park at shopping malls with it.
Edited by Inline 6
lol sounds like my issues dave, sinergy put my tires on and obviously used the wrong size socket on my expensive blue alloy lug nuts. had two rounded out in a big way, they went thru the trouble of filing them off after they got them off to remove the burr they left . only issue was it shows bad on blue nuts when the rest of it is shiny alloy.... trained monkeys , a socket must fit tight on the lugs or the rattle gun kills them when you hit the trigger, its not rocket science ????
Oh damo,, its always better to piss(hear about issues) before you shit(buy a piece of shit)
you could always buy a forden executurd...lol
build a RB30DET GTR driveline, VE holden.. ex cop car...lol talk about stealth
AFAIK those sites are live, so once u submit an ad it is up for the length of time that u pay for (much like ebay)
Or enclose the bottom of the VE, put a few fins on, and turn it into the boat that it is. RWKW? I think not. How many killerwasps do you have at the prop man?
For all you Galaxy, Star-loving people out there...
Earth is tiny compared to these other planets:
http://digg.com/d1ofQT
i didnt know jj.am had educational stuff? i thought it was all just naked chicks and racist gifs.
you know what that all means though? we all gotta start compensating for size of our planet.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
