lol at you Andrew!!!......I'll tell you what scary is when I get back from the toilet and feeding the stupid cat!
stay tuned for a strong response sunshine!
Ok, I've kicked fed the cat, wiped my bum and washed my hands.
What's very scary is when someone can read your thoughts to the letter then post them better than I could myself......spot on Bro!
Bahaha.................you all thought I was going to flame the boy, didn't you. :down:
what else i need for a 100k service?
# 1x Genuine Nissan Timing Belt
# 1 x Genuine Nissan Water Pump
# 1 x Genuine Nissan Thermostat
# 2 x Genuine Nissan Cam Seal
# 1 x Genuine Nissan Crank Seal
# 1 x Genuine Nissan Tensioner Bearing Spring
# 1 x Genuine Nissan Oil Filter
# 1 x NSK/NTN Timing Belt Idler Bearing
# 1 x NSK/NTN Timing Belt Tensioner Bearing
May aswell do the other belts too while they're off.
Oh and also include a lot of swearing :down:
Edited by Jamesrb25
Dave, your S14 must look like this asap
Chekkit
his front tyres are even munching through the gaurds, dedicated,
fair sure i cant afford *any* of that, but will a set of these do in the mean time?
It looks way better with the matching 17/18 stagger, that white car in the link (ie before he chucked the 18s on the front and used the tyre to modify the guard :P)
Those white rims look familiar, do they have high 30 F low 40ish R offsets?
james i got a titanium cat back on mine only the cannon at the end and cat and it aint that loud at all it got a deeper note to it tho
Hmmmm Elmer Fudd's money may have just found a home :P
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
