ps. extreme paintball on chnl 1!!!!
soo good! and did u watch slamball last night hehe!
love one HD
HAHAH I watched that before, was weird watching paintball on TV :rolleyes:
Paid for a 27mm ceffy front sway bar earlier today, should go well with the GTR rear one :D
Won't hit the sump also which is a bonus :blink:
can anyone tell me what this is selling
http://74.125.19.132/translate_c?hl=en&amp...owAPPzvRYZXWM2Q
obiviously its those backyard Japanese porn's steve
as if you didnt know :stupid:
and james i think the translator did go into melt down lol
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
