went and saw fast and the furious last night was good except for the 180sx out the front(dragon) what a piece of crap, dodgy paint job, subs that max'd early then he just kept turning them up sounded crap and he left the engine running for like 2 hours just sitting there.
little lol for this morning
Posted by SoulChimera
Thats what first came into my mind so I stuck a few other games on and they seem fine. Outrun is screwing up without fail, every single time.
It's just done it again half way through a race, here is a picture of what I mean. It's not the best quality but you get the idea.
http://img.photobucket.com/albums/v94/SoulChimera/Outrun.jpg
I hope my 360 isn't on the way out again.
Posted by CVG Gav
I had a similar issue a while back when playing Silent Hill. Does the dashboard look the same when you quite the game or does it clear up?
My Xbox died eventually. No video signal coming out of HDMI at all.
Does it still do it with a component cable?
Yep, dashboard stays screwed up too.
Great, another 360. This will be my 3rd one. Luckily I didn't have to pay for the last one because it was the 3 red rings but I'm guessing I'm not covered for this problem seeing as it's the GPU and it's over a year old?
It's the old premium console so it doesn't have a HDMI port.
all i can say is GG microsoft
i got no idea how microsoft have avoided a massive PR issue, at one point there was like a 80% failure rate on the damn things lol
I think I remember hearing something similar once ^
I've had one red ring too. Luckily it was covered by warranty.
i need to find info about cooking, anyone know of any like sites, or can i search somewhere? thanks in advance
http://www.cuisine.com.au/
i got a bunch of recipes depending on what ur after, lemme know
-D
anyone know where i can possibly buy a car tonight?
something like a keto or some shit
my mums car is f**ked and i aint got nothing to drive
keto is not part of the some shit group!!!
Na, he's right they are shit. There only good for wanna be drifters with no money for a real car :blink:
fark, in need of 90 degree screwdriver. supercheap surely would have them, might pop down in a min..
cant you just use a stubbie one, those 90 degree ones are a pain in the ass to use.
Also, someone please buy my ute, or ask around for me. I've found a new car and need the ute gone.
Edited by DSTROY
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
