went and saw fast and the furious last night was good except for the 180sx out the front(dragon) what a piece of crap, dodgy paint job, subs that max'd early then he just kept turning them up sounded crap and he left the engine running for like 2 hours just sitting there.
little lol for this morning
Posted by SoulChimera
Thats what first came into my mind so I stuck a few other games on and they seem fine. Outrun is screwing up without fail, every single time.
It's just done it again half way through a race, here is a picture of what I mean. It's not the best quality but you get the idea.
http://img.photobucket.com/albums/v94/SoulChimera/Outrun.jpg
I hope my 360 isn't on the way out again.
Posted by CVG Gav
I had a similar issue a while back when playing Silent Hill. Does the dashboard look the same when you quite the game or does it clear up?
My Xbox died eventually. No video signal coming out of HDMI at all.
Does it still do it with a component cable?
Yep, dashboard stays screwed up too.
Great, another 360. This will be my 3rd one. Luckily I didn't have to pay for the last one because it was the 3 red rings but I'm guessing I'm not covered for this problem seeing as it's the GPU and it's over a year old?
It's the old premium console so it doesn't have a HDMI port.
all i can say is GG microsoft
i got no idea how microsoft have avoided a massive PR issue, at one point there was like a 80% failure rate on the damn things lol
I think I remember hearing something similar once ^
I've had one red ring too. Luckily it was covered by warranty.
i need to find info about cooking, anyone know of any like sites, or can i search somewhere? thanks in advance
http://www.cuisine.com.au/
i got a bunch of recipes depending on what ur after, lemme know
-D
anyone know where i can possibly buy a car tonight?
something like a keto or some shit
my mums car is f**ked and i aint got nothing to drive
keto is not part of the some shit group!!!
Na, he's right they are shit. There only good for wanna be drifters with no money for a real car :blink:
fark, in need of 90 degree screwdriver. supercheap surely would have them, might pop down in a min..
cant you just use a stubbie one, those 90 degree ones are a pain in the ass to use.
Also, someone please buy my ute, or ask around for me. I've found a new car and need the ute gone.
Edited by DSTROY
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
