went and saw fast and the furious last night was good except for the 180sx out the front(dragon) what a piece of crap, dodgy paint job, subs that max'd early then he just kept turning them up sounded crap and he left the engine running for like 2 hours just sitting there.
little lol for this morning
Posted by SoulChimera
Thats what first came into my mind so I stuck a few other games on and they seem fine. Outrun is screwing up without fail, every single time.
It's just done it again half way through a race, here is a picture of what I mean. It's not the best quality but you get the idea.
http://img.photobucket.com/albums/v94/SoulChimera/Outrun.jpg
I hope my 360 isn't on the way out again.
Posted by CVG Gav
I had a similar issue a while back when playing Silent Hill. Does the dashboard look the same when you quite the game or does it clear up?
My Xbox died eventually. No video signal coming out of HDMI at all.
Does it still do it with a component cable?
Yep, dashboard stays screwed up too.
Great, another 360. This will be my 3rd one. Luckily I didn't have to pay for the last one because it was the 3 red rings but I'm guessing I'm not covered for this problem seeing as it's the GPU and it's over a year old?
It's the old premium console so it doesn't have a HDMI port.
all i can say is GG microsoft
i got no idea how microsoft have avoided a massive PR issue, at one point there was like a 80% failure rate on the damn things lol
I think I remember hearing something similar once ^
I've had one red ring too. Luckily it was covered by warranty.
i need to find info about cooking, anyone know of any like sites, or can i search somewhere? thanks in advance
http://www.cuisine.com.au/
i got a bunch of recipes depending on what ur after, lemme know
-D
anyone know where i can possibly buy a car tonight?
something like a keto or some shit
my mums car is f**ked and i aint got nothing to drive
keto is not part of the some shit group!!!
Na, he's right they are shit. There only good for wanna be drifters with no money for a real car :blink:
fark, in need of 90 degree screwdriver. supercheap surely would have them, might pop down in a min..
cant you just use a stubbie one, those 90 degree ones are a pain in the ass to use.
Also, someone please buy my ute, or ask around for me. I've found a new car and need the ute gone.
Edited by DSTROY
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
