damo ive decided to go with the N1 ISC's it was a toss up between them and the TEIN Super Streets which i can get for $1900 delivered, and the ISC's are $1500
I reackon 8kg/6kg would be the go for Adelaide raods
anything above that would be too harsh a ride
just get aftermarket sway bars if wanting to improve handling a bit more
don't go too stiff Cara
hey stiff is good,, for some things.lol
but mine is too stiff, shocks you perves..lol, going to raise it up some and loose the ride up, its like driving on the stops,,, hard , cant get traction on rough adelaide roads at all. annoying to drive on south road bumps near me. Newish Bilstiens on mine
hahaha i have 12kg front and 10kg rear my car is so stiff two jacks of a jack and it starts moving off the ground ask Pete not cool great for a race track which is as smooth as a babies bottom but not adelaide roads
mine is like that too, so stiff the car can be rocked on driveways,picks up the rear tire and opposite front one..looks funny as hell, R34 is a stiff chassis to start with. then the nismo LSD locks up in flight.. light throttle or it gets interesting to say the least
jack it up on one corner the whole car lifts up.. not sure the spring weights but its insane stiff,, feels like a go cart, fun on smooth roads , lame on SA roads
ill getting sway bars too that is on my list :thumbsup:
she wont be a daily once the blower is on, but ill prob end up putting the coilovers in once i get them anyway.
if you more more traction for the straight it's better to go softer settings!
and personally i don't like heavy duty sway bars at the front because it made my car understeer!
Edited by nos man
cara, if youre spending this huge amount of money on power, dont cheap out on suspension.
bilstein PSS9 coilovers, whiteline blade adjustable swaybars, adjustable camber, castor, toe, and traction arms, etc etc.
you want 800hp, but wanna put down through cheap suspensions... why?
depend on the application i reckon! if it's more of a dyno/straight line queen then there's no problems really! but trying to handle that much power around corners and stuff, i would be investing alot of money into suspension and brakes!
I think 800hp is what the blower is rated at
600hp would be a more realistic ballpark figure I'd imagine - John Keen would know his stuff however Im guessing that big figures will wear the engine out in no time
Stlll, I've never seen an RB supercharged and I think this is gonna be a really interesting project to watch
-D
yeah pretty much what you have said is correct, i prob wont even bother taking the 34 out on the track (only drag strip)
-D
thats correct ben. the supercharger is rated at 800 hp with a maximum airflow of 1200 CFM. however the 800hp is based on a engine that is running at 100% efficiency, so realistically, its gonna be around 700-750hp which is still alot of power, 750hp= 559 kW..........
my engine is being built by Chris Miltion Engineeting Developments and they have all the information on the blower itself and they are building my engine for the blower.... so the engine will be very strong and able to handl the power no matter what i throw at it.
that is so f**ked
so a minister pretty much gets away with doing what anyone else won't
yeah his credibility is out the window now Krishy so no matter what his future in Parliament entails, he'll never ever be taken seriously again........he'll soon be out altogether me thinks.
don't do it!
At the end of the day, no one can give you any advice Cara until we know what you are gonna do with the car.
Street Only = 4 or 5 kg Front and approx 6 kg Rear with decent sway bars.
Drag Racing = Stock standard suspension for weight transfer
Regular track work = as per what Krishy said above with decent sway bars
Bilstein PSS9......you could do alot worse :wacko:
don't do it!
the car will be show/dyno queen and every now and then drag strip warrior lol
well if that's the case, go as soft as possible and get rid of your 18" rims.......15" or 16" is what you need on the rear
i got 19's pete lol :wacko:
if i was to go on the drag strip id be putting stockies on anyway
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
