Same with ford fairlanes like my daily. They had an rear airbag setup to level the car once a trailer/caravan was placed on the tow bar, Since it was $1000's to fix it once it broke most people replaced it with coilovers once it died.
yeah, factory 'yota bags are pretty average, especially at this age, while its mad fun droppin the ass and liftin the nose on hindley street, theyre pretty useless really. dampening sucks. you can buy 're manufactured' bags from an american company called 'arnott industries', but they have a fairly short life span apparently. hell, you can even buy air struts with bilstein inserts through them. pumps you can find second hand, but even then theyre crazy expensive ($1000 private, up to $2000+ from a wrecker). just get coilovers.
dont be put off by the rather high spring rate you tend to find for coilovers for these things though, theyre heavy beats, so 15-18kg front springs tend to be the norm.
:edit:
pm sent dude, also check this out, stance in the us, theyve got 5 types of coilovers, from your base model stuff all the way to remote reservoir racing stuff, thats a link to the GR+ which is 1 step above entry, 18/10kg springs, which is normal for 'yota gear. enjoy.
then theres; HSD TT Series, HSD HR Series, ISC N1 (says its only available for 97 on though, might wanna check with ryan), and racing logic.
Edited by scandyflick
lol but can those stock airbags be modded easy to get the wheels bouncing off the ground?
nope, for a start the air lines and valves are WAY too small, along with an asthmatic compressor and tired pump, theyre pretty useless, takes forever to lift and drop. only way youd get it bouncing (or moving faster than youre average snail) is a very large airtank, one pump per axel, upgraded compressor, 1/2 inch or bigger lines, and suitable valves... and you know, new struts.
oh Dave some people have no taste :blink:
haha, yeah, its pretty ordinary...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
