i got approx 5litres poured on my lap this morning while driving to work. dato is not impressing me during these winter days :banana:
a slow drip has now become a steady pour :bunny: look forward to calls of har har :bunny:
any 1 got welding skills? apparently the roof has rusted through and my ton of silicon around the window can not stop the onslaught.
Edited by Inline 6
as mentioned previously i have a soft spot for that car. i try to kill it via thrashing but it dosnt die.
ive started looking at cars but all the cheapish cars seem kinda boring, id like to stay rwd n such. so far cars i seen that look alright mini and 280zx
Edited by Inline 6
yeah but 138hp wasnt enough, i somehow think the rolla wont match that. and i used to bang it off the rev limiter when i take off everytime with the auto stick jammed in 1st n 2nd before letting it go into D
i dont care what it looks like more concered how it drives. working heater and no leaks would be a nice touch :banana:
are poobird sss any good? 1.8L
also whats the link to your damn rolla?
Edited by Inline 6
primer :banana: dosnt look to bad might chuck him an offer on it. any 1 wanna get funky with spray cans if i get it? :bunny:
also with the vic rwc that dont mean bugga all diff if your bringing it here does it? Its still gota go through regency all the same?
Edited by Inline 6
you dont need another f**king car, lol, any more and youll need an LMVD.
marrone r32 - track project
white r32 -sold
gold/now black datto - sold
falcon
rolla - chucking CA in it
still leaves the falcoon.
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
