# For high horsepower EFI applications making up to: 1600 HP - Naturally Aspirated
# 1100 HP - forced air induction
# Now with more flow and extended warranty
or
thats the one ill be getting Steve, not cheap on the pocket tho being that its $787 US
lol don't do that, I'll give you $1000 if you eat my cat
Ok just got a P.M from brickersi or something along the lines with a link saying do it, any1 else had this and is it a dodgy link?
yeah. i deleted it the moment i noticed it linked to russia and the guy had 0 posts ;P
-D
Cara, Why dont u run twin 044's with a surge tank. Will be alot cheaper then that fuel pump. I just picked myself up 2 044 delivered for $440. Surge tank around $150-200, then fittings/braided lines around $250, then perspex box to keep it separate from the cabin roughly $200.
Remember it has to vent to the atmosphere and be enclosed to be allowed on the track.
Good turnout at Enfield RSL's dawn service in spite of the rain and it being a Sat... couple hundred there easily :blush:
-D
Largs Bay RSL was packed. Easily 300 people and a few GTR's. One silver R33 GTR plates were VSPEC 3. He couldn't drive though, nearly stalled it twice going up a driveway then had 3 attempts at parking and on the final time hit the gutter.. all you could hear were the rims screaming!
WHAT!!! you have your pumps already??? i haven't got mine yet, could be cos i paid it a little bit later...ill find out hopefully on monday.
I also got a pm from that brickersi, subject was weekend and the only text was a link to a adult singles site in russia, i google'd the link first but didnt click it
aeromotive pumps. awesome. kinda like having the automotive equivalent of a woman in the boot. nothing but whining and sucking.
/flame suit on.
well me and that fuel pump will get a long quite well then wont we? lol
im doing taking the 34 on the track once she is supercharged.
John Keen wants to go with on external fuel pump, but with the way the economy is at the moment, dependong on the cost of the pump, we may go with 2 x bosch. just depends at the time when im ready to get it,
and if i get a surge tank it will prob be a custom one for underneath the car, not in the car.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
