huh.....I thought it was for her 34?!
Your bro must have other issues Carl (condensation in the fluid can have a similar effect sometimes).....Red Stuff has a very low coefficiency which makes them quite effective when cold, mine would throw you thru the windscreen 1st thing in the morning on the way to the shops.
EBC Pads
interesting to see that the effective temp vs braking force at the low end is pretty consitant through the lower end of the range.
looking at that chart, something must have gone wrong with the brake set up, as he used to have yellow stuff on the car, and it was much more streetable than it was with the red.
the brake booster has since been replaced on the pug, i have not had a chance to drive it since then, as its now a hill climb car that lives in a shed.
yeah that does seem somewhat strange Carl.....especially with his experiences with the Yellow Stuff.
Guys like Chad (Dstroy), Andrew (Blue32) and eventually Luke (ENR34), who regularly track their cars, could do alot worse by not at least trying the Yellow Stuff.
For track only, the Blue Stuff freaks me out a bit cause I'm guessing that not only would they squeal like a pig on heat but they would be very hungry on the rotors.......hence why the Yellow Stuff would be a good option......cheaper and quicker to replace pads than rotors.
can i give your car some finishing touches with a shotgun cara?
guaranteed 1st prize !
yeah no dramas carl.....just make sure the design looks half decent ok!
6 or 8 pot?
depends what i can find at the time......maybe just have to go with r33 gtr 4 pot....but considering the car isnt going to be drivin stupidly hard they should be all good for what im gonna be usign her for
they are for the 34 :)
i quite liked the sig!
tis a bit large tho. in consideration, sig scrapped...
BOLOGNESE :)
i see its back again :)
its been reported
a signature by definition isn't a movie its a picture that the community can quickly see who has posted, 1403.43 KB (1437109 bytes) is inappropriate
you may see this as harsh.... to bad
i see its back again :P
its been reported
Maybe you better report your mate Heslo, as his is a movie also.
his isnt 1.4mb
from memory its 600kb edit not even 478.36 KB (489841 bytes) thats why i have never complained about it
yeah Carl cables extreme unlike Sydney we only get 256k upload
lol, there are perhaps some things i can do....
not sure if u are aware, but there is a flaw in the monthly quota being reset, and u actually get unshaped the day before your account anniversary date... so there is the potential to wax about 18Gig on the last day at full speed if u have good torrents or use news groups.
im pretty sure that only works if u are shaped b4hand tho
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
