how bout u try taking on the dato in that ugly bus and we see who comes off 2nd best :) :) all i gota do is scratch 1 of ur panels and itll cost you more to repair than it will to replace my car
LOL Danny Boy.......whatever you do to my truck, I do to you :):P
I normally go around on my own in about 1.5 hours. But depends how good golf we play. OK, let's say 3:30pm at my place, that way we can have a roadie, and be on the course just before 4pm. If it gets to 5:40pm we can give up and head back to my place.
So, SLED is in, Madaz is in. Any other takers?
sounds like a plan bud
4 in a group is all you'd want, yeah
maybe if Talbo can make it that would do for 1 group then anyone else can form a 2nd group?
I see you lurking in here Luke - come play golf tomorrow!
Yeah 4 or so is about the max we want in s group. It is only mess around golf though - we can even have people teeing off on the same hole at the same time to speed things up.
lol par 3 at valley view is heaps fun..havnt been there for a while, i play off of 4 atm but i have work so i cant get out n smack a little white ball around with you guys.. :)
Got pulled over tonight cause apparently , 2 seconds of completely stopping at a stop sign isn't sufficient according to sapol
oh and according to them ive been pulled over numerous times for driving like a (and i quote) f**kwit while i was apparently chasing my girlfriend around :P
keep in mind that according to them this happened in February ...
and my engine seized on the 11th of january... proof
i been single for years now , so how the fk do i have a girlfriend ?
must of been something really strong in my coffee that day to not notice i had a mrs
good one (Y)
lol if you play off 4 you wouldn't be welcome to come play with us assclowns :P
haha ah well..if u guys like to really have fun, take a bottle or two of jim beam, or whatever u prefer, and take two shots after each hole...an instant winner of an idea...if u like drunk golf.
Wow what a night, the ambulance just left my place... my mum was sleepwalking, fell over, split her nose/lip open and blood everywhere. Still pretty shaken up :P
Andrew, would love to golf with ya tomorrow but at this stage it doesn't look possible (work commitments unfortunately) Maybe next time?
Well I'm gonna try to get some shut eye before work tomorrow... night all
Bahahaha
i go outside when i sleep walk :cool:
2 weeks ago (tuesday night) i bought the bin in (bought it up the the front door) (still full) and it didnt get emptied :P
but not funny in lukes situation, sleepwalking is pretty dangerous.
so Talbo just rock up at Valley View at around 3:45pm if you can make it.
:P Should make it if I get out on time...... It's been probably 10+ years since I've played a par 3 course. Fro memory you only use SW/PW/9/8 irons and putter around Valley View.
:cool: yeah can see that ending well for all involved and not getting kicked off the course
5/8/putter for me ;) there is 1 long hole that goes from top of course to the creek
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
