how bout u try taking on the dato in that ugly bus and we see who comes off 2nd best :) :) all i gota do is scratch 1 of ur panels and itll cost you more to repair than it will to replace my car
LOL Danny Boy.......whatever you do to my truck, I do to you :):P
I normally go around on my own in about 1.5 hours. But depends how good golf we play. OK, let's say 3:30pm at my place, that way we can have a roadie, and be on the course just before 4pm. If it gets to 5:40pm we can give up and head back to my place.
So, SLED is in, Madaz is in. Any other takers?
sounds like a plan bud
4 in a group is all you'd want, yeah
maybe if Talbo can make it that would do for 1 group then anyone else can form a 2nd group?
I see you lurking in here Luke - come play golf tomorrow!
Yeah 4 or so is about the max we want in s group. It is only mess around golf though - we can even have people teeing off on the same hole at the same time to speed things up.
lol par 3 at valley view is heaps fun..havnt been there for a while, i play off of 4 atm but i have work so i cant get out n smack a little white ball around with you guys.. :)
Got pulled over tonight cause apparently , 2 seconds of completely stopping at a stop sign isn't sufficient according to sapol
oh and according to them ive been pulled over numerous times for driving like a (and i quote) f**kwit while i was apparently chasing my girlfriend around :P
keep in mind that according to them this happened in February ...
and my engine seized on the 11th of january... proof
i been single for years now , so how the fk do i have a girlfriend ?
must of been something really strong in my coffee that day to not notice i had a mrs
good one (Y)
lol if you play off 4 you wouldn't be welcome to come play with us assclowns :P
haha ah well..if u guys like to really have fun, take a bottle or two of jim beam, or whatever u prefer, and take two shots after each hole...an instant winner of an idea...if u like drunk golf.
Wow what a night, the ambulance just left my place... my mum was sleepwalking, fell over, split her nose/lip open and blood everywhere. Still pretty shaken up :P
Andrew, would love to golf with ya tomorrow but at this stage it doesn't look possible (work commitments unfortunately) Maybe next time?
Well I'm gonna try to get some shut eye before work tomorrow... night all
Bahahaha
i go outside when i sleep walk :cool:
2 weeks ago (tuesday night) i bought the bin in (bought it up the the front door) (still full) and it didnt get emptied :P
but not funny in lukes situation, sleepwalking is pretty dangerous.
so Talbo just rock up at Valley View at around 3:45pm if you can make it.
:P Should make it if I get out on time...... It's been probably 10+ years since I've played a par 3 course. Fro memory you only use SW/PW/9/8 irons and putter around Valley View.
:cool: yeah can see that ending well for all involved and not getting kicked off the course
5/8/putter for me ;) there is 1 long hole that goes from top of course to the creek
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
