yay golf talk lol
i have been playing a fair amount of golf pretty much every weekend.....getting my scores down which is good...best so far has been 32 on 9 holes par 3....anyone keen for a SAU golf day....groups of 4
Edited by Krishy
I normally go around on my own in about 1.5 hours. But depends how good golf we play. OK, let's say 3:30pm at my place, that way we can have a roadie, and be on the course just before 4pm. If it gets to 5:40pm we can give up and head back to my place.
So, SLED is in, Madaz is in. Any other takers?
Fark! I have the day off, but im heading to victor at 12 for end of season cricket trip.
Krishy, organise a golf day!
Par 3 isn't the best of fun though..... Need to go out on a real course where you can at least take the big dog out and try nail one down the middle...... :P
North Adelaide is good for that
Yeah it's not too bad.... there's the Patawalonga as well near the airport as well or for a nice easy 9 hole course there's Regency. Sandy Creek and Mt Barker are a couple of my favs though.....
yay golf talk lol
KEEEEN AS BREW!!!
I make a point to NEVER pull between stationary cars to turn - even if they leave you a gap to do so - it is just too risky if you can't see who you are pulling out in front of. Just because you can't see them, doesn't mean a cyclist or motorcyclist isn't there.
I made that mistake on the side street between kfc and hungry jacks at reynella....everyone had stopped and left a gap..so i went through...some F@&$wit in a camry comes flying up in the turning lane and scared crap out of me so i booted it...luckily i was still n/a , only problem i was open wheel so i just wheelspan....4 cars back was a cop car which rapidly did a u turn and pulled me over to do me for excessive noise....they didnt care that the camry nearly hit me and i took evasive action..imo, they just saw a skyline with stockies
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
