Hey guys,
I'm new to SAU. I have a S13 with a R32 front on and and a BN body kit, but, the BN bumper is alittle low for me and cant quite get up into my car port - lol
So, i was just wondering if anyone could help me out with a front bar or point me in the right direction, i much rather take someones 2nd hand bumper then pay big coins to a pirate wrecker!
Thanks - Brandon
Hey Brandon, last time I saw your car it was still a full S13, sounds like you been doing heaps of work to it! Need to see some recent pics :blink:
heaps of free ring tones
if you right click the actual name of the ringtone and open in a new tab you get a proper url and can link others to the exact one
a lot will like these
http://www.zedge.net/ringtones/921/nokia-n...gtones/6-4-1-1/
for the Tiesto fans
http://www.zedge.net/ringtones/399008/ties...fe-ii-ringtone/
haha :blink: Hey Dion!
Yeah welll turns out its a 180sx with an R32 front on her, picking her up tomorrow morning :) should post photo asap!
thanks for the help guys, just the for sale thread is a little confusing because it shows people from other states but thanks guys!
ill post photos tomorrow :)
Question because I'm abit lazy to search, a GTR Bumper will fit on correct? I don't need the GTR bonnet?
If the conversion was done using GTR body panels and all the spacing is correct then a GTR bar will fit.
If it was done using GTS-T panels etc, then just go in to viva garage and get a GTR copy front bar for a GTS-T for $280
Yeah there is one hole that is 143m. I actually even fail at making that distance with my 5 iron, so will take my 3 believe it or not. I am a short hitter for some bizarre reason (cue Skandy's witty comment here). Especially when the ground is damp and there is no roll, like at present.
its ok andrew. short men are still men. :)
(yeah, pretty weak, im a little off my game today)
ps, its scandy, not skandy. freakin nightrider...
also decided on the wheels i want for the 31. purely cos id rather build the car around the wheels
http://www.roh.com.au/modularseriesventuro.php
chrome dish, gloss black centres. 10.5s will have at least 16cm of forward facing dish :)
17x9.5 -20 front - most likely run a 225 or 235/45/17 Kuhmo KU36 motorsport tyre
17x10.5 -20 rear - more than likely run a 235 Kuhmo Admiral on the rear for skiddies, or 255 KU36s for grip
i spent a few seconds trying to figure out why this sounded familar.
then i remembered the wheels, and sizes are exactly the same as ben was gonna run as track wheels.
another coincidence? gonna get some fat viennas as show wheels too?
:blink:
Edited by scandyflick
haha :D Hey Dion!
Yeah welll turns out its a 180sx with an R32 front on her, picking her up tomorrow morning :D should post photo asap!
ill post photos tomorrow :D
Oh I've seen that 180sx quite some years back at a Small Car Sunday car show and it was for sale back then aswell. Champagne gold colour, looks real nice :)
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
