ha! cool, what do you plan to do in this hugeee field?
I currently do web design and graphics :] heaps of fun and very easy going!
Heh yeah Damo, what way do you want to clusterf**k your brain? :D
<-- Linux System Engineer. Fun stuff.
-D
hmm, not too sure about the job, bets to make a portfolio (a few play around websites and show off what you got )
Im not very good at my job tho, only self taught and did it from yr 9 to 12...
but its fun! you should enjoy it! and if you get days like today (slow day) you can watch movies (Anchorman for me atm) lol
well i currently maintain my works website using a program thats pretty much halfway between notepad and word, not something id stick in my portfolio
thats worth putting in if you want to do webdesign. understanding HTML and XML and all the various standards is pretty much mandatory. Even better if you can get into Ruby On Rails, Perl, Php, SQL and the like... best to do some research and speak to a few people in different professions to find out what u want to do. Webdesign can vary from picture manipulation, to doing backend programming on large databases -very very different roles but come under the same banner.
-D
-D
SQL would come in handy with my current job, could write our own reports for the database instead of contacting Melbourne to get them done!
any of these worth doing? http://www.seeklearning.com.au/short-cours...phic-design.asp
Next week i should be attempting some XAML code, doubt it will go well... but we do need a new media player, and the ones ive seen look very nice!
theres alot of programs that make databasing easy (connecting it to your website etcetc)
my problem is, web standards.. :D stupid IE..
Don't know. are you any good with graphics manipulation already? Most short courses only teach you basic photoshop stuff, to be a decent web based graphical designer you'd be wanting to do at least a years worth of training - possibly at uni aswell...
Speak to some webdesigners first and go from there... SQL is programming, Graphic Design is as far away from programming as you can get. It all depends on your mindset, and whether or not you would enjoy either.
-D
the latest craze in vehicular modifications.
literal horsepower in the engine.
(look somewhere over there ------> if youre soft)
Hungry little fella?
Edited by RubyRS4
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
