ha! cool, what do you plan to do in this hugeee field?
I currently do web design and graphics :] heaps of fun and very easy going!
Heh yeah Damo, what way do you want to clusterf**k your brain? :D
<-- Linux System Engineer. Fun stuff.
-D
hmm, not too sure about the job, bets to make a portfolio (a few play around websites and show off what you got )
Im not very good at my job tho, only self taught and did it from yr 9 to 12...
but its fun! you should enjoy it! and if you get days like today (slow day) you can watch movies (Anchorman for me atm) lol
well i currently maintain my works website using a program thats pretty much halfway between notepad and word, not something id stick in my portfolio
thats worth putting in if you want to do webdesign. understanding HTML and XML and all the various standards is pretty much mandatory. Even better if you can get into Ruby On Rails, Perl, Php, SQL and the like... best to do some research and speak to a few people in different professions to find out what u want to do. Webdesign can vary from picture manipulation, to doing backend programming on large databases -very very different roles but come under the same banner.
-D
-D
SQL would come in handy with my current job, could write our own reports for the database instead of contacting Melbourne to get them done!
any of these worth doing? http://www.seeklearning.com.au/short-cours...phic-design.asp
Next week i should be attempting some XAML code, doubt it will go well... but we do need a new media player, and the ones ive seen look very nice!
theres alot of programs that make databasing easy (connecting it to your website etcetc)
my problem is, web standards.. :D stupid IE..
Don't know. are you any good with graphics manipulation already? Most short courses only teach you basic photoshop stuff, to be a decent web based graphical designer you'd be wanting to do at least a years worth of training - possibly at uni aswell...
Speak to some webdesigners first and go from there... SQL is programming, Graphic Design is as far away from programming as you can get. It all depends on your mindset, and whether or not you would enjoy either.
-D
the latest craze in vehicular modifications.
literal horsepower in the engine.
(look somewhere over there ------> if youre soft)
Hungry little fella?
Edited by RubyRS4
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
