ha! cool, what do you plan to do in this hugeee field?
I currently do web design and graphics :] heaps of fun and very easy going!
Heh yeah Damo, what way do you want to clusterf**k your brain? :D
<-- Linux System Engineer. Fun stuff.
-D
hmm, not too sure about the job, bets to make a portfolio (a few play around websites and show off what you got )
Im not very good at my job tho, only self taught and did it from yr 9 to 12...
but its fun! you should enjoy it! and if you get days like today (slow day) you can watch movies (Anchorman for me atm) lol
well i currently maintain my works website using a program thats pretty much halfway between notepad and word, not something id stick in my portfolio
thats worth putting in if you want to do webdesign. understanding HTML and XML and all the various standards is pretty much mandatory. Even better if you can get into Ruby On Rails, Perl, Php, SQL and the like... best to do some research and speak to a few people in different professions to find out what u want to do. Webdesign can vary from picture manipulation, to doing backend programming on large databases -very very different roles but come under the same banner.
-D
-D
SQL would come in handy with my current job, could write our own reports for the database instead of contacting Melbourne to get them done!
any of these worth doing? http://www.seeklearning.com.au/short-cours...phic-design.asp
Next week i should be attempting some XAML code, doubt it will go well... but we do need a new media player, and the ones ive seen look very nice!
theres alot of programs that make databasing easy (connecting it to your website etcetc)
my problem is, web standards.. :D stupid IE..
Don't know. are you any good with graphics manipulation already? Most short courses only teach you basic photoshop stuff, to be a decent web based graphical designer you'd be wanting to do at least a years worth of training - possibly at uni aswell...
Speak to some webdesigners first and go from there... SQL is programming, Graphic Design is as far away from programming as you can get. It all depends on your mindset, and whether or not you would enjoy either.
-D
the latest craze in vehicular modifications.
literal horsepower in the engine.
(look somewhere over there ------> if youre soft)
Hungry little fella?
Edited by RubyRS4
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
