im getting one too. :P
id heat wrap it, but thats just cause im lazy and cant be arsed with heat shields.
I thought you got the GK dump, or did you end up sending it back?
I have access to a fair amount of the adhesive reflective heat shield material that I figure I can stick to anything that might be affected if need be. I can't see myself upping the boost or driving it hard enough to warrant heat wrap.... but if there's something I might have overlooked...
I'm going to be getting a AM dump front pipe as soon as Andrew has made one for me, do you guys think it needs heat wrap... keeping in mind I run stock boost?
Suppose it depends whether you're running a pod or an enclosed CAI. If the later, probably no real need but if you're running a pod, may make a difference in summer by removing some of the under bonnet heat.
Again, a wise choice :P Considering getting a whole system?
No. I have an Apexi N1 Evolution cat back I bought from an interstate forum member in December last year collecting dust in the garage, I'll get this fitted when I get the dump/front and cat fitted.
No pod SLED, factory intake with apexi panel filter.
still got that pos... sold the front pipe, still selling the dump pipe. couldnt be arsed arguing for a refund, so im just selling the shit. luke called andrew the other day while he was helping me with my turbo and i decided id bite the bullet and buy an AM dump and front.
ns? :laughing-smiley-014:
nothing like a real cornish pasty Stevie
depends on what u call real
the cornish pasties they sell arent quite authentic, being that theyre just meat and vege mix in a shortcrust
a true cornish pie (as was made for the miners) would be comprised of a meat section and a fruit section (representing the main course and the desert respectively) and the end would be a big knurled section of pastry that would be thrown away (since the miners hands would be covered in coal soot)
you might have the forward section made of beef and peas or something like sausage and potato, and the second section would be diced apricots or plum pie... usual cornish fare, but baked into an all-in-one snack
trivia 101. you may leave cash donations on my door.
-D
into these cornish-pasty.jpg now are we :P
Thats a samosa dude.
I have a rad samosa recipe, with ground beef, tumeric, cumin, garam masala, salt n pepper, garlic and a pastry made from wheat and butter, deep fried to orgasmic perfection
whoever ur wife is, she wishes she had a dohmar right about now
-D
-D
for the record,
i aint making u no frikin cornish pasty,
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
