Angle Park tonight anyone? :P
http://www.grsa.com.au/hunniegalleries.aspx
Heres a tip: Race 2, Number 3, Movie Dollar.
just in case people think its just a normal Greyhound Racing website, heres a sneak peek:
been thinking of going and seeing them....how much was it rubes?
$69 from memory. Was absolutely excellent. The stamina and fitness of these guys (and girls) is amazing. And there's some excellent humour in there too.
However, if you park there, the volunteers there will encourage you to pay the $12 pre-paid fee claiming its cheaper. cops arse! ... they're trying to get more $ outta you. Show goes for just under 2 hours ... so pay after and you'll pay only something like $7.50. Or park anywhere else but the Festivla Theatre.
anyone any had any plastic welding done?
looking for a point in the right direction.
thanks in advance.
Morsell's on South Road, Mile End have done all my plastic welding. The guy is good, but can be busy at times.
Edited by RubyRS4
im going to see a professor at flinders medical centre today to be interviewed about my recovery since i shattered my left elbow a few years back...
will definitely be sharing my opinion on how it was fixed the first time :P
has been 4 operations since the initial one to fix that mess
Guest CleanAndSimple
ha, one of my mates ex's/ on of my old friends is in that
ive called up Martini and waiting for a call back, they are looking into all the oil and such to find the right ones i can use on the rolla, cause i want to change all the fluids in her cause i dont have a record at all of the service history.
intense science experiments to get the right forumula, might be a bit rude of me but come on its a bucket of sh*t id imagine.
just change the oil with anything incase its been 10yrs since that happened last and drive it into the ground. the oil will prob cost you more than the car did
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
