step 1 ask for advice on what mods to do to your car
step 2 take days off work, spend thousands on car in various workshops
step 3 wait till the next person complains about the mods you have done and begin from step 1 again
:( That about sums it up.
BTW got my Cooling Pro delta fin intercooler this week. Fill that big mouth in the front bar now :(
I'll stick my current Cooling Pro fmic on the silver Stagea.
Also planning that manual conversion for the black stagea in the next few months :P ... then track time!
Selling stolen phones and cronic :( thats how u afford gtrs kids
:P:(
Reminds me of when I was in year 9, I was at Marion with a bunch of mates. And a bunch of gangster guys came up to me and said "hey man, you want a mobile?" and I was like "nah" and he pulled out a old 3315 and said "$100." and I said "dude, I don't even work"
The good old days of playing Snake on a Nokia 3310/3315!
i had 3310 and droped it 3stories, cover came off but went back on and worked just fine :P
gota love the old briks. kept mine for ages, nearly got as much abuse as my dato :(
speaking of which discussions have began on possible rebuild, might start looking into doing a full restoro on it. yes ill fix the damn window and roof :( will be a longer term project after i finish uni. figure it will be good car to play with that way if i break anything it dosnt matter
Edited by Inline 6
My dad had a 5110 and I played snake on it all the time, then I had a 3310 and that was awesome, and I had an 8210 along the line aswell as a 6510 and that was a bad ass looking phone.....
...and like when the 7210/7250 came out with colour screen omg that was like sensational!
Ones Ive had that I can remember are: 5110, 3210, 3310, 8210, 2100. Some LG thing, a ZTE F850 (it was free), and some other Nokia before this one... 5100? It had 3G, 2mp camera, wifi etc. And now a Apple iPhone.
I've always liked the Motorola Razr's. My mum has had a couple of different razr's and I think they are pretty good
Edited by 93GTST
is it me or are psi boost gauges rare as hens teeth?
yes theyre rarer because they are using INCHES as the measurement and are imperial
Bar is metric and mmHG is a scientific measure.
I bought my psi VDO gauge from gaugeworks. They have several different types
-D
Wow ... I just landed an awesome job at work! (sense the sarcasm?)
Create a directory on our intranet and transfer 10 years worth of Development Plan CDs onto it. 12 CDs per year x 10 years = over 100 CDs (some months had no Development Plan editions) @ over 500MB per CD of info = massive headache. Some of the CDs are beyond their shelf life and not reading properly for the transfer. Oh goody!
:P
yeah, but its not too hard to convert bar-psi in your head.
math not ya good subject? :P thought watching for card counters you would have some skillz
real cars come with boost gauges :P and only milk n juice come in 2LT etc etc
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
