fail. got bored and started refitting my turbo, had to take all the lines off to fit it on, put the turbo back in, new gasket, bolted up, lock tabs ready, start refitting the lines, water feed, done, water drain, done, oil feed... well yeah... turns out i cant get the oil feed on with the turbo on. fail. lol.
Looks neat Ruby :P
Got a call from AM Andrew, my dump/front pipe should be ready today :D
heslos bring mine around for me today. :D
got a pic of it the other day, looks much awesome.
:edit:
new cooler looks good ruby, how was the fitment? will have to look at ordering mine pretty soon me thinks.
and enough working on my car for now. cant get the f**king oil fitting on the block to go back on. ill attack it again after a few hours sleep i think.
Edited by scandyflick
Fitment was easy. Didn't even need to remove the front bar. Took all the measurements I needed, removed old fmic and piping, make up some sturdy brackets for mounting the new fmic, slide it into place, bolt up. Check position/center ... tighten mounting bolts. Then fabricate up the pipework ... that took a while :P Still using the old silicone hoses and clamps, looking for new ones this week.
Good to know I can still weld :D No leaks, and neat welds. I pull the piping all off later this week/weekend to tidy up some of the splatter and paint it satin black. Fmic will stay polished this time :P
Because I have the type M bar now, the old fmic looked 'sad' in that gapping mouth :P The delta fin fmic suits the bar well and I was able to mount it lower than the previous fmic, allowing more flow to the cooler. :D
I'm interested in getting a dump/front pipe combo... can u PM me details of how much it cost?
cheers
-D
Pm not working for me at the moment!
$360 for the split dump and $250 for 200 cell hi flow cat. Not sure about dumps and front pipes for RB26 though.
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
