fail. got bored and started refitting my turbo, had to take all the lines off to fit it on, put the turbo back in, new gasket, bolted up, lock tabs ready, start refitting the lines, water feed, done, water drain, done, oil feed... well yeah... turns out i cant get the oil feed on with the turbo on. fail. lol.
Looks neat Ruby :P
Got a call from AM Andrew, my dump/front pipe should be ready today :D
heslos bring mine around for me today. :D
got a pic of it the other day, looks much awesome.
:edit:
new cooler looks good ruby, how was the fitment? will have to look at ordering mine pretty soon me thinks.
and enough working on my car for now. cant get the f**king oil fitting on the block to go back on. ill attack it again after a few hours sleep i think.
Edited by scandyflick
Fitment was easy. Didn't even need to remove the front bar. Took all the measurements I needed, removed old fmic and piping, make up some sturdy brackets for mounting the new fmic, slide it into place, bolt up. Check position/center ... tighten mounting bolts. Then fabricate up the pipework ... that took a while :P Still using the old silicone hoses and clamps, looking for new ones this week.
Good to know I can still weld :D No leaks, and neat welds. I pull the piping all off later this week/weekend to tidy up some of the splatter and paint it satin black. Fmic will stay polished this time :P
Because I have the type M bar now, the old fmic looked 'sad' in that gapping mouth :P The delta fin fmic suits the bar well and I was able to mount it lower than the previous fmic, allowing more flow to the cooler. :D
I'm interested in getting a dump/front pipe combo... can u PM me details of how much it cost?
cheers
-D
Pm not working for me at the moment!
$360 for the split dump and $250 for 200 cell hi flow cat. Not sure about dumps and front pipes for RB26 though.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
