hey guys, can anyone tell me if the R33 GTST S1 and S2 ecu's are interchangable?
i've tried searching but have found mixed answers.
i know there are ignition differences to take into account - ie S2's do not use the ignitor mounted on top of the motor + different coilpacks etc. But will this matter if say i threw a S2 ECU in my S1?
any help is appreciated!
>_<
i hope mine wont have to sit that high?
is there any reason why it is?
well it might have to sit that high because in that pic it's already sruggling to get any lower!
but i don't see why a s1 and s2 ecu is different! as long as they have the same plug/loom and the mapping should be the same!
i would say it doest matter here is why
it doesnt matter where the spark is located its the timing that need to be the same
if it really matters that much to you i have a S1 ecu
thankyou
edit - yeah I will ask him, cheers steve.
theres nothing wrong with my s1 ecu, i've just got my eyes on an aftermarket ecu suited to s2.
Haha, don't tell me you were the dude in the black 33? I was in the silver V35 just leaving his place :(
LOL! Yeah that was me, sorry for parking where I did and making it hard for you to get out of there.
@ Steve - I don't think it's that expensive at all. I've seen the quality now and frankly I'd say it's actually a bargain for that quality in SS. >_<
well i sold my work rims a while back! the black ones with the red lip and i've got a new set. buddyclubs with the same sort of look, black with the red lip because i really wasn't too happy with other looks so i went back to what i was happy with
@ Steve - I don't think it's that expensive at all. I've seen the quality now and frankly I'd say it's actually a bargain for that quality in SS. :closedeyes:
:laugh: Not a worry mate, small world eh?
Andrews stuff is indeed quality, you WON'T be disappointed! What did you get made up?
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
