hey guys, can anyone tell me if the R33 GTST S1 and S2 ecu's are interchangable?
i've tried searching but have found mixed answers.
i know there are ignition differences to take into account - ie S2's do not use the ignitor mounted on top of the motor + different coilpacks etc. But will this matter if say i threw a S2 ECU in my S1?
any help is appreciated!
>_<
i hope mine wont have to sit that high?
is there any reason why it is?
well it might have to sit that high because in that pic it's already sruggling to get any lower!
but i don't see why a s1 and s2 ecu is different! as long as they have the same plug/loom and the mapping should be the same!
i would say it doest matter here is why
it doesnt matter where the spark is located its the timing that need to be the same
if it really matters that much to you i have a S1 ecu
thankyou
edit - yeah I will ask him, cheers steve.
theres nothing wrong with my s1 ecu, i've just got my eyes on an aftermarket ecu suited to s2.
Haha, don't tell me you were the dude in the black 33? I was in the silver V35 just leaving his place :(
LOL! Yeah that was me, sorry for parking where I did and making it hard for you to get out of there.
@ Steve - I don't think it's that expensive at all. I've seen the quality now and frankly I'd say it's actually a bargain for that quality in SS. >_<
well i sold my work rims a while back! the black ones with the red lip and i've got a new set. buddyclubs with the same sort of look, black with the red lip because i really wasn't too happy with other looks so i went back to what i was happy with
@ Steve - I don't think it's that expensive at all. I've seen the quality now and frankly I'd say it's actually a bargain for that quality in SS. :closedeyes:
:laugh: Not a worry mate, small world eh?
Andrews stuff is indeed quality, you WON'T be disappointed! What did you get made up?
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
