Stupid Shell service station ...
Filled up at Shell (was real low on fuel ... couldn't make it to BP) with their 98 fuel. Stagea has been idling like shit since. And it was right after filling up at Shell. Half the drive home was perfect before then. :ninja:
hahaha never had no drama's with shell you sure you used the red pump and not the green or yellow one
i even thought after running BP for a year and switching back to V-power my car had more guts and i know cubes uses V-power a lot of boys over melbourne and sydney have no troubles with it :D
i even thought after running BP for a year and switching back to V-power my car had more guts and i know cubes uses V-power a lot of boys over melbourne and sydney have no troubles with it :)
Doesn't change the fact that the stag only started playing up after my stop at Shell ;) ... and 'yes' I know the diff between red, green and yellow. :D
I use V-Power regulary and havent ever been dissapointed with it. I found the car runs best on V-Power and Ultimate, and some other brand fuels not so much. I got stuck once and had to get 95 premium, didnt have as much guts (by a long shot) as the other ones.
I once made the huge mistake of trying V-Power in my S15 - car ran like a dog and started pinging its ring off. Luckily I had only put in half a tank, so could top it up with decent fuel and some octane booster so I could drive the thing.
I'll grab some octane booster tomorrow. Didn't think of that. Too pissed off at the time ... stopping and lights and missing and shit.
Better still. I'll just ride the Brutale to work tomorrow. :D
Lesson learnt: if its not BP ultimate, then its only half tank of whatever high octane.
Edited by RubyRS4
MUD crabs eewwww yes i heard that on life FM yesterday, did you get my txt message the other day about reading the advertiser page 18 it was about bikie clubs and getting done by association
yeah got it bud but didn't get to read the paper........just the usual dribble, was it?
I only ever catch up with the Longriders in their rooms on the 1st Frid of every mth but haven't been there lately and they haven't been made 'out of bounds' yet.
If they continue their occasional association with the Jokers they may come unstuck and I'll stop going.
GTR's use a 25 box too its just the series 3 has different 3rd gear sychros
EDIT
Pete they had a scenario of some guy that had 2 cousin or some shit and made a bid story of it was a large article too bit to articulate
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
