Stupid Shell service station ...
Filled up at Shell (was real low on fuel ... couldn't make it to BP) with their 98 fuel. Stagea has been idling like shit since. And it was right after filling up at Shell. Half the drive home was perfect before then. :ninja:
hahaha never had no drama's with shell you sure you used the red pump and not the green or yellow one
i even thought after running BP for a year and switching back to V-power my car had more guts and i know cubes uses V-power a lot of boys over melbourne and sydney have no troubles with it :D
i even thought after running BP for a year and switching back to V-power my car had more guts and i know cubes uses V-power a lot of boys over melbourne and sydney have no troubles with it :)
Doesn't change the fact that the stag only started playing up after my stop at Shell ;) ... and 'yes' I know the diff between red, green and yellow. :D
I use V-Power regulary and havent ever been dissapointed with it. I found the car runs best on V-Power and Ultimate, and some other brand fuels not so much. I got stuck once and had to get 95 premium, didnt have as much guts (by a long shot) as the other ones.
I once made the huge mistake of trying V-Power in my S15 - car ran like a dog and started pinging its ring off. Luckily I had only put in half a tank, so could top it up with decent fuel and some octane booster so I could drive the thing.
I'll grab some octane booster tomorrow. Didn't think of that. Too pissed off at the time ... stopping and lights and missing and shit.
Better still. I'll just ride the Brutale to work tomorrow. :D
Lesson learnt: if its not BP ultimate, then its only half tank of whatever high octane.
Edited by RubyRS4
MUD crabs eewwww yes i heard that on life FM yesterday, did you get my txt message the other day about reading the advertiser page 18 it was about bikie clubs and getting done by association
yeah got it bud but didn't get to read the paper........just the usual dribble, was it?
I only ever catch up with the Longriders in their rooms on the 1st Frid of every mth but haven't been there lately and they haven't been made 'out of bounds' yet.
If they continue their occasional association with the Jokers they may come unstuck and I'll stop going.
GTR's use a 25 box too its just the series 3 has different 3rd gear sychros
EDIT
Pete they had a scenario of some guy that had 2 cousin or some shit and made a bid story of it was a large article too bit to articulate
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
