mate its your daily that makes you look old....lol and dusty
didnt you see the memorial post, the dato's dead. passed away month ago. rusted and busted
n i call you chicks feisty felines atm :P
Edited by Inline 6
lol more random plans outa you, depends on what the engine is what you putting it in me thinks.
swapping a l28 in a l26 dato would be a sinch, but dropping that rb26 in my dato might take some custom work me thinks :P
engine mounts fuel injection alterations, blowing the welds on intake
Edited by Inline 6
who knows how to do a engine swap? how long would it take?
Just the engine complete with box. About a day depending on your tools and skills.
Including changing loom, ecu etc ... f**k that!
RB25DET Neo
When you said you wanted something powerful from me ... I didn't think you meant my Neo motor! :P
In that case, you'll need the loom and ecu as well won't you? As above: f**k that!
Engine swap itself will be easy ... with a hoist.
Edited by RubyRS4
see if john can do it for you Cara, workshops have the required tools and knowledge to do it all in one go for you
go T51R SPL with a small supercharger for that down low response :P
yeah i know damo but its still gonna cost abit in labour if i get him to do it for me, if i can get the engine in and everything i would like to just have to take it to him for tuning.
loom is pretty much the same at GTT and i got a power fc which is for GTT anyway :P so i think i should only have to get FMIC and boost gauge?
You might find there are a few add-on bits on the turbo version of the Neo
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
