does anyone have a power fc HAND CONTROLLER that could suit of a 32/33 gtr power fc computer that i could just test on mine?
need to find out if the djetro versions work with my computer as im not sure if mine computer is a djetro. itll only take a few minutes :D
Front part of the exhaust will need changing too. Buy a GTT, much much simpler when considering registration hassles too....
umm not really.. same make of car, release with different engine, all you should have to do is break upgrade and its 100% legal!!!
I'm not free till 3:00-3:30 due to work after which I'm going to Super Cup but I'll make sure if you need it that it's available for you
thats all good dude, im in no rush just wanted to know which HC is going to work on mine so i dont buy the wrong one :D
give me a msg or call whenever you free. ill be at drifts on sunday though :(
ok, so wtf happened with the cruise up at windy point tonight?
i rocked up, didn't even get to see anything. just got out of car, cops arrived... went for a quick walk, 5 min later empty car park and a cop car leaving the scene???
where the hell did everyone move on to? think i spotted typevu's car in the carpark but not 100% sure, only had time to park and that's it.
was the cruise any good? :(
I dont know what happened either. I was coming in a bit later, so I called someone I know and he said they are heading to Lofty (from Clarendon or something... I dunno), well a handful of cars rocked up and thats about it. Were a few different groups around, dont know if they were reminants of the cruise...
Turned out to be a good night, did some camera work.
I don't know the in and outs of it all but regardless it's a waste of time anyhow!!!
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
