YOU MEAN HER EAR?
local sporting teams, i hear the local basketballs going well :D half the teams dropping out the rest struggling to survive.
nba sweet as always, Lebron busting crazy buzzer beaters to win the game n scoring 40 odd points n such :D unfortunately foxtel has a gay love affiar with kobe bryant and only shows his games though ;)
1 HD has been showing the playoffs and some of the moves are so damn good
The bball has been real good.
James needs to pass the ball more. the reason he gets so many points is because he will shoot when others would rather set it up.
Ofcourse he's usually good enough to do it tho
kobe used to be the master of this 2 years ago, take that shot over 5 players when everyone else is wide open.
i aint been watching his full games just the highlights, he did pass up the shot at the end of the 1st game that could have won it out for someone else to throw a brick up
Only prob I have with the game is the huge egos. and sooks.
Fav player is still Ray Allen I'd day. classy and a normal dude. used to like Grant Hill.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
