i could do that eventually but atm i would rather get the stock gtt engine in and go from there too cause i can use the head off the N/A engine for the 25/30 combo
so are you putting a GTT engine in, and building the 25 N/A head with 30 bottom end?
I wanna do a 25/30 build too. Lets do it together Cara :P
Would like: RB30 bottom end, RB25 top end, cams, cam gears, top mount manifold, HKS 3071 ... as a starting point.
But which car to put it in :)
morris oxford...power to weight like strapping a jet to a skateboard
Cara,
You should have a look at the lewis engines website as it has got me thinking right now.
www.lewisengines.com.au
here you go Cara, from their website:
TRUST TDO6 used two hours after rebuild. made 340rwkw on rb25 @20psi. $800.00
RB30/25 'TORQUE MONSTER' engines $6,900.00
Dis wat u want??
looks the goods :P
I wanna do a 25/30 build too. Lets do it together Cara :)
But which car to put it in :P
sounds like a good idea ruby :D cant wait lol :P
might have to check that out a bit more damo, cheers
oh
btw
what do you think would be better?
apexi power fc boost control kit (for about $730) or greddy profec b spec II boost controller (for about $579)
let us discuss.
:P
Nengun has the pfc boost control for around 470 delivered? I guarantee Luke ENR can get it cheaper too... Both are fine, just depends if you want another device in your cabin or not i guess.
Thinking of building a little project myself ...
RB20 block
RB25 crank
RB26 rods
Forged pistons (1mm oversize)
Ported head
Adjustable cam gears
Custom cams
Top mount manifold
HKS 3071 turbo
... for starters!
Want car to put it in? :P
cara is like a little boy that listens to backstreet boys, while wanking off to a picture of britney.....doesnt know what she wants.
thats my take on it anyway.
now, my LAST attempt to get this footage from sat night up on you tube, if it doesnt work, im gonna give up!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
