i could do that eventually but atm i would rather get the stock gtt engine in and go from there too cause i can use the head off the N/A engine for the 25/30 combo
so are you putting a GTT engine in, and building the 25 N/A head with 30 bottom end?
I wanna do a 25/30 build too. Lets do it together Cara :P
Would like: RB30 bottom end, RB25 top end, cams, cam gears, top mount manifold, HKS 3071 ... as a starting point.
But which car to put it in :)
morris oxford...power to weight like strapping a jet to a skateboard
Cara,
You should have a look at the lewis engines website as it has got me thinking right now.
www.lewisengines.com.au
here you go Cara, from their website:
TRUST TDO6 used two hours after rebuild. made 340rwkw on rb25 @20psi. $800.00
RB30/25 'TORQUE MONSTER' engines $6,900.00
Dis wat u want??
looks the goods :P
I wanna do a 25/30 build too. Lets do it together Cara :)
But which car to put it in :P
sounds like a good idea ruby :D cant wait lol :P
might have to check that out a bit more damo, cheers
oh
btw
what do you think would be better?
apexi power fc boost control kit (for about $730) or greddy profec b spec II boost controller (for about $579)
let us discuss.
:P
Nengun has the pfc boost control for around 470 delivered? I guarantee Luke ENR can get it cheaper too... Both are fine, just depends if you want another device in your cabin or not i guess.
Thinking of building a little project myself ...
RB20 block
RB25 crank
RB26 rods
Forged pistons (1mm oversize)
Ported head
Adjustable cam gears
Custom cams
Top mount manifold
HKS 3071 turbo
... for starters!
Want car to put it in? :P
cara is like a little boy that listens to backstreet boys, while wanking off to a picture of britney.....doesnt know what she wants.
thats my take on it anyway.
now, my LAST attempt to get this footage from sat night up on you tube, if it doesnt work, im gonna give up!
    • You're already well into "gearbox is a consumable" territory there. A billet plate will either make it (effectively) 1% stronbger or make it last one more pass. At some point you'll probably tear 3rd gear into small chunks and regret all the life decisions that came before it.
    • ..and forum.r31skylineclub has been down all week....anyone know why?
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
