do an rb20/30 Rubes :)
Doing some shopping around.
Thinking an RB30/25 build for one car, and an RB22.5(25)/20 build for another particular car. And I'm not talking about the car(s) you think I am. Then get the plate RRB 225 = Race RB 2.25 lt
:P
that will go nicely in the volvo aye ruby :D:P
Cara if your after 300 at the moment then you will something like a GT3071 + cams +porting + lots of boost and you may just still fall under 300kw but it will be more responsive that the other option which is a GT3076 which will make 300 with cams and has the potential to make more.
As for the RB25/30 build, if you are after a big power engine then do yourself a favour an go for a 26 head straight away. 26's have all the good stuff straight away like solid lifters and cams to suit as well as not having the VTC gear which you can't run with big cams. Although the NEO's have the solid setup they have a problem with an exposed oil gallery once you go over 9.25mm of lift and therefore your potential power is limited. The other good thing about the 26 heads is the availability of aftermarket parts like a wide selection of cams, valves, springs etc etc.
you have pretty horrible taste in women craig...
Thinking of building a little project myself ...
<shopping list>
... for starters!
Want car to put it in? :P
R31 Excel GT, Series 2, rolling on 15x8 -5 SSR Mesh fronts and 15x9 -15 Longchamp rears with heavily flared guards. sitting on the deck of course.
problem with that is, with the irs setup they run being designed somewhere back in early 1850's, youd be putting the diff through the earths core everytime you got on the gas.
Edited by scandyflick
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
