hahaha that .gif has been getting around hey.
scandy that vid is sweet. pitty about the music IMO, i love seeing euro cars linking corners
i thought the music suited the drivers and the cars attitude pretty well actually.
and heres one that isnt as fun as the last video, but cool none the less. gixxer 1000 powered vw polo.
Edited by scandyflick
Got my AM dump front + hi flow cat fitted up properly this morning by Andrew and I must say it is awesome. More response, turbo spools faster and overall there's more bottom end. Fantastic customer service from Andrew and a top bloke, I'd recommend his products to anyone. :)
^^ thank you that is why i recommend Andrew his customer server outperforms most, and he is a great guy to chat too
Hey Steve, what area is Andrew located in, might have a couple of jobs for him both on the daily and the 33
omg, one drunk bogan without headlights on his falcon crashed in hills last night and people are again blaming it on cars with "spoilers and mag wheels"... http://www.news.com.au/adelaidenow/story/0...5006301,00.html
Why do we need to build a racetrack when we have Mallala? Likewise these idiots say if they had a drag strip these things would not happen. Has anyone besides me heard of Adelaide International Raceway? Why should I, as a hard working taxpayer, have to folk out money so these moronic idiots can act like juveniles on a racetrack? If they want one they can bloody well pay for it with higher registration!!
Posted by: The idiotic youth of our roads
what a city of whingers is this is... no offence, but cant wait to move back to qld...
What the hell was he thinking? :)
^^ thank you that is why i recommend Andrew his customer service outperforms most, and he is a great guy to chat too
+1. Hence....
[poor camera phone pic]
I should also mention that my dump/front and cat that I purchased from Andrew DID NOT require modification to go as first thought.
i see you were lucky enough you got your comment published... mine got rejected as usually and it was pretty much only what i wrote in post above  :iluvff:
they usually only accept comments supporting their side of story... and i thought newspapers were not supposed to be biased...
seriously, just about anyone could become journalist in australia looking at quality of journalism here... hoon stories in advertiser and bra stories on ACA seem to be australian journalism at its peak...
the message here is if you are a retard that repeated every school year 3 times, failed at just about anything, dont have any qualification/education whatsoever but are not in physical shape to do anything with your hands: become a journalist or a cop... or maybe a road safety minister
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
