i said hi to Anthony this arvo for ya mr THE SLED :) He still remembers you and your gtr
haha, ole Anthony Chucky Norris is a good lad....I reckon Adelaide Engine was his very 1st job, when he was just a snotty nosed little kid.
Has he kissed and made up with his brother yet?
yeah nice looking "R32" there .... and it's non-turbo ewwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww
Lmao.... not only does it say r32 GTR when it is clearly a R34 gt they quote the engine size at 2.6l non turbo. I was TOTALLY fooled. Definately a GTR... this is on my must have list.
7 psi i think i read was the max u could do on the stock internals.
but the learning experience in doing a DE+T would be good!
go thicker gasket to run more boost? it'll be safer as well
but i quite liked your first intial idea of going for the tomei 2.8 kit! it could've really been a real weapon with the right cams
I don't think so Pete. I made the mistake of calling his brother "Anthony" a few weeks ago and he didn't look impressed :(
He understood it was a genuine error and didn't think I was taking the piss.
Spent the morning getting of a small hangover.
Spent the arvo pulling all my FMIC piping off and replacing all the clamps. Still waiting on the silicone reducers, but I'll keep using the old ones. Lex has bought my old fmic kit (including piping, clamps and reducers) and he's been patiently waiting for me to get the whole kit together.
Weekends are never long enough :)
LOL, I can see where this is going......"headlines"......."BLUE MESH, it's more than flyscreen, it's a way of life!"
hahahahahaha nice work Pete!!!!!! we should get a sticker made up for Ruby so he can put it on the Stag :)
i wonder how hard it would be to fit one of these bad boys under the bonnet of the 31
Mack RM6-285 - 11.3L 285HP inline 6 with 285hp / 1150Nm torque
probably difficult, but more important - do you want to use 31 for towing lol?
Edited by Rocky88
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
