i thought government workers didnt do any work??? or is that council workers...lol
Come on man dont be hating on the Govt employees....we i mean i do a lot of work just that the networks are slow in the country side what can i do
Check out nurses.
blue mesh packaging now includes the following message
WARNING: MAY LEAVE PHYSICAL/EMOTIONAL SCARRING. RICE MODS PTY LTD IS NOT RESPONSIBLE FOR ANY DAMAGE PHYSICLY OR EMOTIONALLY THIS PRODUCT MAY HAVE
WARNING: VIEWER DISCRETION IS ADIVISED, THE SIGHT OF THIS MESH MAY OFFEND SOME VIEWERS
you'll never hear the end of this :P
has become the most common butt end of all our jokes :P
Edited by Inline 6
I'm sooooo going to get something like that made up for when the Stagea is in car shows :P
Warning: Blue mesh may cause Retinitis Pigmentosa (retina blindness) and has been known to cause emotional scarring (lackness of HTFU). "Fear the Blue Mesh" is not responsible for any physical or emotional damages arising from the use or misuse of blue mesh. Please observe from a safe distance at all times.
:P
Edited by RubyRS4
ever worked in a hospital?? i think they are a myth... most nurses are actually rather old and not what i'd call hot. however the traniee doctors... giddy up!!!
Thats only true if your stuck in a metro hospital Luke heheheh :thumbsup:
Country hospitals seem to have more hot nurses then city.....interns umm some of them can be quite hot
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
