lol drunken weekends....friday night..drove to stansbury...played a game of "scumbag" (cool card game)....saturday...rode motorbikes....thrashed cars...blew a bluebird radiator to bits doing a burnout on my uncles burnout pad....fixed it and kept going....got drunk as a monkey sat night in front of the bonfire which was visible from the port river expressway....sunday...kinda hungover...watched my wife do helis in her v8 falcon out in the paddock...drove home...played guitar hero metallica.....monday...slept in....re concreted my missus's nannas letterbox in after some punk kid broke the pole it sits on....got a box of endone for my troubles...went home...whipper snippered the front yard...cut firewood..got fire going...took endone...sat watching telly...comfortably numb :happy:
my weekend rocked
saturday. sat and bored myself shitless with a heap of lessons for this army drivers course. came home, went for a mud bash sat nite
sunday: went to u pull it for a couple of bits, sold my roof rack to a mate in the arvo, then went for a big mud bash with luke and flick and a few of my mates
monday: went across town and worked on the skyline all day, then worked out i had homework from this drivers course, so went for a drive last night
today: RDO, finishing my homework off hehe
Damn ...
Stagea is stuck in 3rd gear. A/T light flashes at me and stag drives in 3rd gear (since lunchtime today). Had a service and shift kit installed by MV Auto 10,000kms ago ... whole car only 61,000kms old. Anyone got any ideas? I've already hit up the Stag section for an answer.
:happy:
Registered the silver Stag today, so I guess thats a sign to take the black stag off the road for a while. :ninja:
maybe the speed created by the downforce of the JDM MESH caused some to dislodge and wrap around you transmission dooflickey
i think it is related to the blue mesh....too much downforce, power, torque almost too much everything really with that BLUE MESH :happy:
i think since the blue mesh has given you too much power etc your transmission cannot handle it anymore.....time for more blue mesh and a better trans maybe.....
on another note check if your ecu hasnt gone into limp mode.....if using aftermarket ECU maybe check the data and see if there is something unusual in there....goodluck with it all ruby
No aftermarket ecu. Stock ecu does appear to be in limp mode. I've browsed the Stagea and Transmission threads and have a few options (although none are definite solutions). I'm going to start with the easiest solution and work my way up to the harder (expensive) solution, by checking the trans fluid level first. I doubt its the solenoids (and hope they're not) as the car is only 61,000kms old and MV serviced the box less than 10,000kms ago ... plus the shift solenoids are expensive!
If all else fails, I guess I'm doing that manual conversion sooner than I thought. I'll also check the Mv invoice for the warranty period and have them dianose the box problem. I'll drive the silver stag around in the meantime.
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
