Life Story entry #319: thinking of going to the Blokes Expo this weekend.
Who else is intending on going to the Blokes Expo this weekend at Wayville Showgrounds?
:P
Yeah i am thinking of going out there and having a look see
whats the bloody point, theres no chicks there
I think you will find the complete opposite on this expo Dan
just in case anyone here is interested...http://www.nissansilvia.com/forums/index.php?showtopic=389082
Ya can't sneak it in that way ... its gotta go into the for sale section. :P
bahahaha nice try i would say that the mods would be onto this.....take it to the FS section mate
cooling pro? have fun fitting it.
ive had to remake all my pipes, either because theyve had huge welding dags inside the pipes, have been too long, or have been bent at the wrong angle, on top of having to make my own brackets, replace 2 silicon joiners, and source my own bolts and spring washers. all with the following response from jjr; "you get what you pay for."
Damo's kit that Jenkies and me installed went in ok, cooler pipe just rubbed on the fan a little. Intercoolers are about the only cheap parts i would fit to any of my cars.
No too obvious, but maybe it was so obvious that he got one, knowing we would think it was obvious and come to the conclusion that he didn't, when he actually did.
Confused yet? :mad:
Hint: its not a volvo ... its not a brap brap!
It has 4 wheels and 4 doors ... and a turbo!!!
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
