Boozing on an empty stomach = get hammered quick = the fun begins earlier!
hrm
reminds me of when i went to moonta. was up to fix some computer issues at the local hospital so I figured I'd also spend a day fishing off the jetty, so I pitched a tent at the caravan park and went to do my work. by the time I'd finished, the only thing open was the bottleshop - no servos even... ended up buying half a dozen old crow premixed bourbon (8%) and proceeded to the jetty with my fishing rods...
after staggering back to the tent and passing out at some unknown time, I woke up in the morning and my intestines felt like i'd been drinking lava.... my mate who had joined me was in an equally bad state (old crows are rough as) so we packed up and headed down to the cafe next to the clock tower... ordered a big big feed of bacon, eggs and toast which really hit the spot
after getting in the car, my mate just couldnt hold on, and as we were turning out of the main street of moonta, he unwound the window and projectile vomited several metres - amazingly he didnt get any on the car... was a waste of a good breakfast tho
-D
bahahahahaa fail
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>&">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>&" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350" />
hey SLED, dont take the new truck anywhere near the cold stuff. Forum member from Albury posted this on Thursday
200 Series Cruisers.
Today it dropped to -1 degrees and that was all a bit much for the 200 series cruisers at work. We have 4. All 4 of them would start then shut down. People thought diesel was too cold.
My TD42Ti Patrol and TDCi Focus started just fine as did the work Ford Rangers.
Then we rang the other work site. Same problem, and they refuel at a different place so it wasn't a bad batch of fuel.
Looks like they are scared of a little frost!!! Ha ha.
Rang Toyota. They had no idea. Said we might need Alpine blend! At -1!!! WTF!!! Local stations don't even supply Alpine!
I'm am happy with my old school TD42Ti!
im heaps good.
just ate 3 slices of shaved ham 4 days past its use by date.
thought it tasted a bit wrong.
meh, shot of bundy should fix it.
ahaah didnt u eat some out of date meat not long ago n spent the next day on the shitter??????
ahaahahah hope it happens again, so it teaches u a lesson.......... :P
Well, picking up another front bar to replace the 'hacked' front bar this morning. Its not too bad on the eyes ... but its a temp anyway for now. Tracy and I have a buyer for our house, so after settlement the 33 will get a decent kit. I'm happy for peeps to shot me pics of what they think looks noice ... keep in mind its a 4 door :P
We're thinking a suitable/subtle front bar (Aero type R or similar), type M skirts modded to fit, and pods for the rear.
:(:laugh::):yes::laugh::yes:
:(:yes::):yes::laugh::P
I likey!!! Now ... how much do they cost? :laugh: I like the rims too ... what are they? Anyone?
How much diff is there between S1 and S2 kits?
Oh, and I got offered a swap with my current 19" Impuls for 18" Impuls, but have not heard back from person and can't recall who they were. Is it anyone here? :rofl:
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
