andrew, trade you the s14 for i... wait, its auto yeah? never mind.
anyone know if a s13 diff will fit in my rolla?
need something stronger
r31 diff. cut and relocate the mounts. voila. hilux diffs should work too.
Sooooo, if anyone knows anyone who might be interested in buying my R34, please let me know. Taking quiet "eio"s at this stage, as I don't really want to sell it, but have my eye on something different .... mine makes 230rwkw and I just added up a shopping list of mods I have done to it and it totals around $12k of extras. I am hoping for around $25k.
Asshole, 'sif you won't tell :P
R35 GTR in gunmetal grey? :P
so the only thing u gotta move is the dungeon toys and the gimp u got chained in the basement? :) Best to hire a ford panelvan and do it during the cover of night
-D
Nah, got it all to fit in a Hiace during the day :banana:
just found some really old pics of my old ET pulsar. bout 4 years ago.
thinking of getting another one for some stupid reason. daily maybe
Hehe Awesome. I love flashbacks :banana:
I got one too. 1988 TX5 Turbo
I got this car when I was 15, did a few things to it: 2.5" zorst, HD clutch (already in), TS VeePort BOV, Boost Gauge etc. Full sound system. That thing had balls. I was its 3rd owner, with the previous owner owning it since 1990, but it was starting to show its age a bit in 2005. So I got it a full respray to freshen things up a bit. Sometimes I regret selling it, would be an awesome daily. Good Times :)
When I got it
When I sold it
Edited by 93GTST
Laptops people. Who makes good ones? Dont need no top of the range shit. Just basic stuff. Would be good to play alright games etc Roughly around 1500ish to spend. And where to buy?
Toshiba Satellite A300. Got mine for $1400.
http://laptops.toshiba.com/laptops/satellite/A300
HAPPY BIRTHDAY CARA!!!!!!!!!!!!!!!!!!!!!!!!!
Try calling Darren from Print and Media Warehouse. They're good with laptops.
Or also try Grays Online. I got my last two laptops from them ... cheap!
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
